Question Dark rock pro4 or slim?
paniczer0
17
Hello, i have a corsair carbride air 540 and i am wanting to put an i9-11000k, MSI z590 torpedo MB, Corsair Vengeance RGB Pro 32GB 2x16 DDR4 3600 (PC4-28800) C18 AMD optimized memory into this case. will the Darkrock pro be worth the $20 more and fit or would the slim be the safer way to go?
Carbide 'Pro'? I can't find that model. Can you double check that?
What is the i9 going to be used for?
A)Just game, either is fine... but if spending on an i9, might as well get the larger cooler...
B)Got some work that will load up all the cores? Then skip the Slim.
Ok, then either cooler will suffice.
Whether the DRP4 will be worth the additional $20 is something only you can answer, due to different personal views on money.
Games don't use that much power. Users sometimes see higher core temperatures because of the gpu in the system.
