This evening a shdow appeared in the bottom right corner of my screen , The shadow goes away briefly if I tilt the screen just right, but I can't hold it there.
Thanks for your helps 🙏
You could try and open up the monitor and see if there is a loose or broken cable. But it def something with the back-light. Tilting it might just be putting pressure on the faulty connection.
