Hey guys
I've recently bought DS through steam, installed it, changed the compatibility issues related to running it with windows 8 only to encounter serious problems when loading the game.
The game starts fine and progresses to the top menu, when I press start the game freezes causing the sound to skip repeatedly and all inputs are not received ie alt+f4 and ctrl+alt+del a few seconds after this my pc shuts off and then reboots. I have updated all my drivers and re installed the game but still am confronted with the same issue. I checked the event log for the shut down and found the following information:
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 3/05/2014 3:50:36 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: SeansPC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>3</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2014-05-03T06:20:36.485248000Z" />
<EventRecordID>2718</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>SeansPC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
</EventData>
</Event>
I'm hesitant to think that it is a psu problem because this dosnt happen for any other games
Any help would be great as I'm at wits end trying to resolve this issue and atm its a wasted 50 bucks.
If you need any more info let me know
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: SeansPC
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
