ssilviu250 :
I want to a dashcam in case of an accident or something, so i don't really need like hours of footage as you mentioned gopro just to watch it back like those people showing on youtube the beauty of roads/landscape as they drive, i just need the 5 mins prior to the event, so that's why i was curious about this function
Right.
As noted, my dashcam does rolling 3 minute segments. Delete the oldest as it goes along.
And g-sensor, to lock that particular segment in case of a crash.
Or manually invoking the lock by the user.
Most of them do this.
On mine:
https://www.amazon.com/gp/product/B071KC51PY
"Sensitive G-sensor☆Specific files will be automatically locked when required(such as car was been hit), even though the car does not start, the recorder will automatically turn on and record the emergency after shaking. So it can provide the evidence when emergency happened and supports the parking monitor. "
So if you have this function turned ON, even if the camera is OFF, it wakes up and starts recording upon impact, and locks that particular segment.
Or, if the camera is currently ON, it locks that segment upon impact.
On mine, a filename for a regular 3 minute segment is thus:
REC01423.AVI
A locked segment would be
SOS01424.AVI.
Easy to tell what is what.
