I honestly have no idea what else to do, decided to come here for help since ya'll so tech savvy, much more than me. This is a bit of a mess and more than one screw up, I'll try to explain the best I can and sorry in advance for the long read.
I have a 1TB SSD on my laptop, split into two 500GB partitions, C (for Windows, programs etc.) and D (for pictures, backups, documents, etc.). I had 200GB left on C and 100GB on D, and wanted to move some of that space from C to D. On the Disk Manager, I could shrink up to 40GB, which I ended up doing (only 30GB). But then, I couldn't just expand D for the same amount, as, for what I understand (and what a friend of mine who is a computer engineer and was helping me with this explained), it wasn't continuous and so I couldn't just add it to D. Ok, fine, I ended up just putting those 30GB back into C.
When he came about to help me with this, we downloaded a tool to help move those 30GB, called Paragon Partition Manager 17 CE. So, with it, we shrank C for 30GB again, and then moved those to D. We left it running while I had lunch. When I came back, some error popped up, I don't recall exactly what, but basically it failed to finish (I have no idea why, seems like the SSD turned off in the middle of the operation - the pc didn't shut down or went to sleep, only turned the screen off from being away for like 30min, that's it). The result was me having a D partition in Disk Manager fully unallocated (all 500 GB of it).
After this it was a whole search for tools that could help me get my partition back, as he said it almost definitely has all the data there, just can't "see it". So I got EaseUS Partition Manager, he did indeed find the partition and that it was in good state for recoverability (and it showed that it still had 400GB used of 500GB total, which was 100% what I had before all of this mess). We hit recover, it recovered it, and gave it a new letter, F. All seemed good, although now I didn't have access to the disk, we just changed the security settings on it and, supposedly, I sort of got access. So, it seemed we fixed the issue. Well, not really.
After this, we got a couple prompts. One saying that the "Recicle bin of F was damaged. Do you want to empty it?". We got a bit confused, we denied it at first. Then we got another prompt from the notification bar saying there were some errors in F and that Windows needed to restart to fix them. We, changed the letter of the partition in Disk Manager from F to D to see if that would magically fix the issue, but nope. We didn't know what to do, if we could just ignore the prompts, I still didn't have access to the folders under D (even after letter change), but I feel it was because of when my friend tried to give me perms, something didn't get 100% right.
So, and now I feel like this was the real screw up, I think I hit "Yes" on the recicle bin prompt and then we restarted the pc. While restarting, on the 1st screen, it now showed "Scan and Fix: Stage 1/2" and went on to do "something" I have no clue what, but it basically screwed me over even more. After coming back, I went to see the disk on "This PC", and D was there indeed, but now showed "260GB free of 500GB, instead of the 100GB it should show. Seemed like data got deleted. Still didn't have access to the folders, but this time I tried to change the perms myself and what was missing last time was that I needed to ADD myself again in the security tab, so I did that and now I could access what was left in D. Indeed data was missing, a lot of it. We ran the Partition Manager again, and this time he couldn't find anything. On the Disk Manager, now C and D were right next to each other and somehow those 30GB were AFTER D (not after C and before D as before).
We decided to get some more data recovery tools, so we got Disk Drill and EaseUS Data Recovery Wizard. Ran both and both could find lost data in D, Recicle bin and that unallocated 30GB partition. We decided to merge those 30GB with D, since now I could (seems like the 1st program did indeed manage to move them after reboot/reboot finalized the move) and since it seemed like it had data from D anyway. Ran them again and indeed I think they found everything that seemed lost BUT it's a bloody giant mess. Nothing is where it's suppose to, most things have random names, etc. And the thing is, both of them, when I run them on D, they find 800GB worth of content to recover, which is around double of what I had (if I remove "existing data" it's around 700GB of recoverable data). Also, during the partition moving or whatever that stupid program/Windows did, I somehow ended up with C files in the recicle bin (which I only know because I ran the data tools on it, they don't actually show up in it).
So, the thing now is, I have no idea what to do/if there's a way to revert this/get the files where they are supposed to be, with the names they are supposed to have. I have an external HDD with 1TB where I have a backup of D at 100% and some things from C (game save data, etc.),but its' from September (yes, I know, that's awful, and I have no idea why it's been so long since I did a backup, I really thought I had one from March or so, since I do one after each semester). So, with it, I can just copy over everything from it to D, but I'm afraid that I will actually lose stuff if I do it before recovering things, since I'll be adding data to it. I decided to order another 1TB external HDD just so I can recover things into it. But now I'm not sure if I should use EaseUS or Disk Drill (although I'm tending more into EaseUS), or if I, for example, use one to recover things, copy them over to the new HDD, and then use the other to scan things again, to make sure I got everything. can I do that? What happens after the first recovery (basically does it move the data into the HDD or copy it?)?
Basically, my idea was to recover the data into the new HDD, copy back everything from the old HDD that has the September backup (it has 305GB worth of data in the D backup; my SSD only has 190GB on D at the moment), and then run through those 800GB and copy over whatever is left (which would be around 95GB, since I had 400GB at the start).
I also ran AOMEI Partition Assistant and got some damaged sectors on both partitions (more on the D partition). I'll try to leave pictures of that (not in english, but I think everyone can easily understand the important parts). I know it can happen over time, just not sure if this fast/this many or if it could have been caused by this mess (I got the SDD in September +/-).
Now, is this the best option? Is there a way to basically "reverse" what we did and the several screw ups (like move the partition again, etc., I don't know)? When I recover the data, is there a way for it to be organized again/recover the paths/names of the things so I can just copy-paste everything back into D (many files/folders are "organized", but most aren't)? And regarding the C files in the "lost" recicle bin, Should I retrieve those as well into the external HDD and the copy them over? I feel like that bit is going to be a bit hard, since many files (system files) I have no idea where they belong. I feel like the final solution would be to get all the data possible out of the laptop and then just fully format it, C and D. Ah, also, the recicle bin prompt still shows up when I open folders in D, and if I run a disk check for D the notification that tells me to restart the pc to fix the issues shows up again, so now I don't even shut down my laptop, just put it to sleep.
Any help/explanation is MUCH appreciated. I find this so absolutely stupid and unfathomable how it happened. Besides my and my friend's screw ups, and not having a good backup from a more recent date, I feel like both the program and Windows did a major "opsi" that I really would like to revert.
Sorry for the long read, I had no idea how else to put his, besides explaining it properly to give the best picture of what happened/what's left, so somehow someone can help me out with this.
Thanks in advance to everyone! You're all awesome!
