Data Recovery on Bit Locker Encrypted Drive
tabraizali
Commendable
Oct 5, 2016
I have a 250 GB Drive with 4 partitions and locked 3 of the logical drives with Windows Bit Locker, now i accidentally recreated the partition from Windows XP Installation setup, i have tried many data recovery software like Recuva, EaseUs Data Recovery and many others but i am unable to get back my data, if any one know what to do please tell me..
Once you partition the drive, you will get nothing back from an encrypted volume.
You need to have backups on a separate drive to keep things like this from happening.
Encryption is good for keeping things private, but it's also not a simple thing to work with then there are drive issues.
The thing is i re-partitioned the whole HDD and the old system was also installed there, i have the Recovery Keys written in text file but how to put where to put ? the drives are empty, bit-locker is removed, some recovery software recovered file without extension and their size are in GB's.
P.S my English is weak
