Archived from groups: microsoft.public.win2000.dns (
More info?)
Kevin: Per your request...
The errors from NetDiag /fix:
DNS test . . . . . . . . . . . . . : Failed
[WARNING] Cannot find a primary authoritative DNS server for
the name
'lan001.LANConcepts.com.'. [RCODE_SERVER_FAILURE]
The name 'lan001.LANConcepts.com.' may not be registered
in DNS.
[FATAL] Failed to fix: DC DNS entry LANConcepts.com.
re-registeration on DNS
server '192.168.10.5' failed.
DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE
[FATAL] Failed to fix: DC DNS entry _ldap._tcp.LANConcepts.com.
re-registera
tion on DNS server '192.168.10.5' failed.
_ldap._tcp.Default-First-Site-Name._site
s.LANConcepts.com. re-registeration on DNS server '192.168.10.5'
failed.
_ldap._tcp.pdc._msdcs.LANConcepts.com. r
e-registeration on DNS server '192.168.10.5' failed.
_ldap._tcp.gc._msdcs.LANConcepts.com. re
s.gc._msdcs.LANConcepts.com. re-registeration on DNS server
_ldap._tcp.6b823874-4752-4aa4-97b6-23c9d
83b8821.domains._msdcs.LANConcepts.com. re-registeration on DNS server
'192.168.
8.5' failed.
[FATAL] Failed to fix: DC DNS entry gc._msdcs.LANConcepts.com.
re-registerat
ce5b4d6d-b668-4d78-9c11-292a1a81636f._ms
dcs.LANConcepts.com. re-registeration on DNS server '192.168.10.5'
failed.
_kerberos._tcp.dc._msdcs.LANConcepts.com
.. re-registeration on DNS server '192.168.10.5' failed.
_kerberos._tcp.Default-First-Site-Name._
sites.dc._msdcs.LANConcepts.com. re-registeration on DNS server
'192.168.10.5' fa
iled.
_ldap._tcp.dc._msdcs.LANConcepts.com. re
_kerberos._tcp.LANConcepts.com. re-regis
sites.LANConcepts.com. re-registeration on DNS server '192.168.10.5'
failed.
[FATAL] Failed to fix: DC DNS entry _gc._tcp.LANConcepts.com.
re-registerati
_gc._tcp.Default-First-Site-Name._sites.
LANConcepts.com. re-registeration on DNS server '192.168.10.5' failed.
_kerberos._udp.LANConcepts.com. re-regis
[FATAL] Failed to fix: DC DNS entry _kpasswd._tcp.LANConcepts.com.
re-regist
[FATAL] Failed to fix: DC DNS entry _kpasswd._udp.LANConcepts.com.
re-regist
[FATAL] Fix Failed: netdiag failed to re-register missing DNS
entries for th
is DC on DNS server '192.168.10.5'.
[FATAL] No DNS servers have the DNS records for this DC
registered.
From c:\ipconfig /all:
C:\PROGRA~1\SUPPOR~1>ipconfig /all
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : LAN001
Primary DNS Suffix . . . . . . . : lanconcepts.com
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lanconcepts.com
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : 3Com 3C920 Integrated Fast
Ethernet
Controller (3C905C-TX Compatible)
Physical Address. . . . . . . . . : 00-E0-81-28-4B-63
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.10.5
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.10.15
DNS Servers . . . . . . . . . . . : 192.168.10.5
From AD Users & Computers: LANConcepts.com
Forward Lookup Zones: LAN-Concepts
(same as parent folder); Start of Authority; [7],
LAN001.lanconcepts.com, admin.lanconcepts.com
(same as parent folder) ; Name Server; LAN001.LANConepts.com
(same as parent folder) ; Host; 192.168.10.5
LAN001 ; Host; 192.168.10.5
That's all I have in my Fwd Lookups.
Thanks for your interest, Kevin!
On Wed, 23 Jun 2004 08:52:14 -0500, "Kevin D. Goodknecht Sr. [MVP]"
<admin@nospam.WFTX.US> wrote:
>In news:j9mid09r3eb279ebvmssg2n2gq8dt5eidh@4ax.com,
>Fran <Fran> posted a question
>Then Kevin replied below:
>> I am having some backup issues with new clients and I'm trying to
>> resolve them. On another NG I got some great advice on cleaning up DNS
>> issues to fix this and it seems to be working. When I ran DCDiag I got
>> several errors about the DC not being configured. So I flushed the DNS
>> cache (Ipconfig /flushdns) and ran Netdiag /fix. I got several errors
>> when I ran NetDiag /Fix like:
>> [WARNING] Cannot find a primary authoritative DNS server or
>> the name '[server].[domainname].com.'. [RCODE_SERVER_FAILURE]
>> The name '[server].[domainname].com.' may not be
>> registered in DNS.
>> There was a whole list of these errors. I tried a quick search on the
>> internet but didn't come up with much (in english, anyway
>> Both NetDiag and DCDiag fail with errors. This is an active directory
>> domain controller (Windows 2000 serverr) and the only DC on the LAN. I
>> have suspected DNS issues for a while but didn't realize how
>> integrated DNS was with AD so I'm fishing now to fix these problems
>> for them.
>> The controller points to itself as the primary DNS controller and all
>> the workstations use DHCP and point to this DNS as well.
>> Any thoughts on how I can diagnose and properly fix these issues?
>At this point without exact errors we can only guess.
>Can you post for us this info:
>1. ipconfig /all from your DC
>2. AD domain name from AD Users & Computers.
>3. List of zones in DNS Forward Lookup Zones.
>Exact error messages in your event log.
>Best regards,
>Kevin D4 Dad Goodknecht Sr. [MVP]
>Hope This Helps
