DDR3 1333mhz not detected on G41m-VS3 R2.0
arick4eva
6
Please advice.
I just bought a Kingston 4gb 1333mhz ddr3 yesterday for my AsRock G41M-VS3 R2.0.
When I turned on the computer, nothing happens just black screen. No sounds from the mobo. Is it a faulty RAM, RAM not supported, or do I need to tweak some settings.
Sorry, DOA=dead on arrival, any part that will not do anything once installed.
RMA=return merchandise authorization, Contacting where the part was originally purchased (or the manufacturer) and opening a complaint ticket.
My CPU = Intel Pentium E6600
I tried setting the jumper and still the same.
If I put the old one back DDR3 2g, system runs normally. If I put both in or only the 4g, then nothing happens.
Btw, if it matters, my DDR3 2g = Kingston KVR1333D3S8N9/2, my DDR3 4g = Kingston KVR13N9S8/4.
When you mix the different RAM together, if they work then you are fine, but if they don't work together then it is a little bit tricky. You need go to the BIOS either set to 1066MHz or up the voltage a little bit ( like to 1.55V ) if you set the speed at 1333MHz, because your CPU has the FSB1066 so that 1333MHz is for OCing.
I was thinking about it but this would be my 1st attempt to OC. That would mean I have to enter BIOS without the 4g ram on 1st, tweak the settings, then put on the 4g ram and see what happens, right? 😛 Which voltage would that be? What would the worst scenario be... fried CPU and/or ram? :ouch:
D.O.A and RMA stands for? (sorry, I'm not fluent in English 😀)
Thanks a lot. I was thinking of it too. I just want to make sure that I didn't miss any steps to make it work. Otherwise, I might get a replacement and still have the same problem with my pc due to my lack of knowledge. So base on the informations I have given, the 4g ram should have worked without BIOS tweaking or do I need to choose other types of ram?
I have tried increasing DRAM voltage to 1.55v but still nothing happens when I put the 4g on. For the DRAM freq., only options were Auto/400mhz DDR3_800/533mhz DDR3_1066; I tried all settings and same result. Anyway, thanks for the help. :)
Yes. Thanks a lot. I will try to get a replacement tomorrow and hopefully it will turn out well :)
Hi there, don't know if you still need help but here it goes.
There are several types of RAM - DDR, DDR2, DDR3 etc, several frequencies etc. But there is also one other thing, the memory density, High or Low density, in other words, the number of memory chips it has.
I had the same problem that you have. I bought a DDR3 4GB 1333Mhz and it was a high density stick, it was 8 memoy chips. I had to buy a new memory, and this time it works. Check that
Check also this
http://www.techrepublic.com/blog/user-support/ram-upgrades-watch-for-high-and-low-density-requirements/
I'm having a similar issue with exactly the same board. But looking at the number of chips to know if the memory is low density or high density does not convince me. I also have two Kingston memories, the non working one has the S9, the working other does not, both are DDR3 1333 MHz, and both have 8 chips.
It seems the board has problem recognizing the newest modules. Maybe we can try updating the BIOS.
hello could you solve the problem? because I just bought one and I have the same problem
I have the same problem (black screen, no sound) with GOODRAM DDR3 4096MB PC1333 CL9 GR1333D364L9/4G.
Old RAM (corsair ddr3 1333 4gb) works fine on the newest BIOS firmware 1.90
Same with me. Motherboard is brand new, on startup no post, no beep code. Tried with several different pairs of Kingston HyperX Fury 1333 2x4gb sticks. Mobo apparently is not designed for newer 1333 ddr3 modules. Unfortunately I don't have slower ram to test it.
No, BIOS update does not solve this. The update is labeled "Improves memory compatibility" but in this case nothing changed. I spoke to the store where I bought the stick, they told me this is not the first case of incompatibility. They accepted the stick back and returned me the money as they do not have another brand to offer me right now.
I used the money to purchase two 2GB Samsung memories (they work in dual channel, mother is very fast with them).
I have the same problem kingston 4gb 1333 do not work i have to buy 1 pair of CRUCIAL SPORTS XT of 4gb 1600 and they work flawless! !!!!! End of problems the MOBO runs like hell and have windows 10
Configuration:
Xeon X5460 3.13ghz fsb 1333
8Gb (2×4gb 1600) crucial sports xt
Asus nvidia Gtx 650ti
PSU corsair 500w 80 plus bronze
