I Ivailo indzhov Distinguished Dec 20, 2015 31 0 18,530 Dec 22, 2015 #1 I have athlon x3 450 3.2ghz i will OC the CPU
Solution unreal9400 Dec 22, 2015 Go for 1333 MHz. The athlon x3 450 was released back in 2010 I don't think it will benefit much from 1600 MHz memory.
J juanrdp Honorable Nov 7, 2012 857 0 11,360 Dec 22, 2015 #2 If you could run it at 1600 Mhz the higher the better... Upvote 0 Downvote
M Mammatus Reputable Apr 8, 2015 99 0 4,660 Dec 22, 2015 #3 For what?!?! Gaming??? If yes, buy the cheaper one!!! You wont notice any difference (or VERY negligeable) in FPS between both! Upvote 0 Downvote
unreal9400 Distinguished Aug 4, 2012 1,913 0 20,460 Dec 22, 2015 Solution #4 Go for 1333 MHz. The athlon x3 450 was released back in 2010 I don't think it will benefit much from 1600 MHz memory. Upvote 0 Downvote Solution
