DDR3 1600MHz with 1.4 voltage
dsmax_s
6
Hello,
Wouldn't be problem if I set DRAM Voltage: 1.4, and I do not overclocking CPU (36x100Mhz), please?
Timings: 10-10-10-28-1
Original DRAM specs:
KHX1600C9D3/4G,
JEDEC standard 1.5V (1.425V ~ 1.575V) Power Supply
Best,
Max
As I said, you will have to lower RAM frequency for it to work properly but it will not harm the rest of your system if that's your concern.
I would like to know if I set RAM Frequency: 1333MHz with 1.35 voltage so is that configuration good/healthy to my RAM's and my machine life's, please?
