Hi All,
So I've just finished building my new setup and everything seems to be fine except for the RAM.
I'm currently running x4 sticks of 8gb at 3200MHz operating in dual channel.
GSkill Tridentz (2x8 @3200MHz) in DIMM 1 & 3, and Corsair Vengeance (2x8 @3200MHz) in Dimm 2 &4.
Motherboard is the Asus Strix Z270E. CPU is the i7-7700K. XMP enabled on BIOS.
As seen in the images, Speccy says RAM is operating at the speed of 1600MHz despite the fact that it also states that the maximum bandwidth is 1066MHz. Task manager displays RAM running at 2132MHz which is 1066MHz running in dual channel.
There's a slight difference in CAS Latency in both the Corsair and GSKILL sticks. Doubt that'd be the cause though.
I'm open to any suggestions and I'd like to thank you for your input in advance.
Cheers
Cheers
