Question DDR5 not running at full 6000mhz ?
OwiHH
Commendable
Jul 25, 2021
28
i bought a new PC
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: X670 AORUS ELITE AX
BIOS: F6c (type: UEFI)
and
Corsair 32 GB KIT DDR5 6000 MHz CL36 Vengeance Grey für AMD
the ram currently runs with 4800 mhz the bios said.
3d benchmark shows it with 3500 mhz
what is the problem?
I got back to BIOS
XMP/EXPO was off.
I turned on XMP and saved restarted.
Windows loaded up.
To recheck if the ram is correct i restarted windows and loaded up the bios.
RAM Status showed 4800 MHZ
XMP showed the correct DDR5 EXPO 1 6000 CL36 RAM
i exited without saving.
Windows not restarted and loaded up the recovery Screen.
I restarted again and loaded up bios to turn xmp off again - after that it took my a few restarts/resets (around 15) to had the PC load up even the bios- very weired.
Memory Type DDR5
Memory Size 64 GBytes
Channels 4 x 32-bit
Memory Frequency 2992.8 MHz (1:30)
Memory Max Frequency 2800.0 MHz
CAS# latency (CL) 50.0
RAS# to CAS# delay (tRCD) 50
RAS# Precharge (tRP) 50
Cycle Time (tRAS) 96
Bank Cycle Time (tRC) 146
Uncore Frequency 2994.0 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR5
Module format UDIMM
Module Manufacturer(ID) Corsair (7F7F9E0000000000000000000000)
SDRAM Manufacturer (ID) Samsung (CE00000000000000000000000000)
Size 16384 MBytes
Max bandwidth DDR5-4800 (2400 MHz)
Channels 2
Part number CMK32GX5M2D6000Z36
Manufacturing date Week 47/Year 22
Nominal Voltage 1.10 Volts
EPP no
XMP no
AMP no
EXPO yes, rev. 1.0
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 22.0-23-23-43-65 @ 1333 MHz
JEDEC #2 28.0-28-28-54-82 @ 1666 MHz
JEDEC #3 30.0-30-30-58-88 @ 1800 MHz
JEDEC #4 32.0-33-33-62-95 @ 1933 MHz
JEDEC #5 36.0-37-37-70-106 @ 2166 MHz
JEDEC #6 40.0-40-40-77-117 @ 2400 MHz
JEDEC #7 42.0-40-40-77-117 @ 2400 MHz
EXPO profile
VDD Voltage 1.350 Volts
VDDQ Voltage 1.350 Volts
VPP Voltage 1.800 Volts
Min Cycle time 0.333 ns (3000 MHz)
Max CL 36.0
Min tRP 11.99 ns
Min tRCD 11.99 ns
Min tRAS 25.31 ns
Min tRFC 0.29 ns
EXPO timings table CL-tRCD-tRP-tRAS-tRC @ frequency
EXPO #1 36.0-36-36-76-112 @ 3000 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR5
Module format UDIMM
Size 16384 MBytes
Channels 2
EPP no
XMP no
AMP no
EXPO yes, rev. 1.0
EXPO profile
Max CL 36.0
Min tRP 11.99 ns
Min tRCD 11.99 ns
Min tRAS 25.31 ns
Min tRFC 0.29 ns
DIMM # 3
SMBus address 0x52
Memory type DDR5
Module format UDIMM
Size 16384 MBytes
Channels 2
EPP no
XMP no
AMP no
EXPO yes, rev. 1.0
EXPO profile
Max CL 36.0
Min tRP 11.99 ns
Min tRCD 11.99 ns
Min tRAS 25.31 ns
Min tRFC 0.29 ns
DIMM # 4
SMBus address 0x53
Memory type DDR5
Module format UDIMM
Size 16384 MBytes
Channels 2
EPP no
XMP no
AMP no
EXPO yes, rev. 1.0
EXPO profile
Max CL 36.0
Min tRP 11.99 ns
Min tRCD 11.99 ns
Min tRAS 25.31 ns
Min tRFC 0.29 ns
ok ive read that somewhere in the past. Good to have it confirmed.
So that i get such error if i turn EXPO on @ bios is based on the restriction for 4 Dimms that cant handle 6000 with 4 slots ?
Is it correct to let EXPO off with 4 Slots?
