DDU safemode problems
NaXos Gaming
Commendable
Jan 7, 2017
111
sooo i ran ddu and it said somerhing like next boot is going to be in safemode and i was like ok i know my pw all tho i normaly used pin
it booted in safemode of some sort and i typed my pw and i was like wrong pw and i typed it again same shit wrong pw and i restarted my pc and found i booting into safemode again
i then spend 45 min trying to ger into adwanced options to reset my pw but whenni finaly got in i had to type it to get cmd like wtf
i ender up being like ok they finaly fixed windows security
but i aint good for me and i still stuck here in the login screen trying to guees my pw
plz i need all the help i can get i got half a terabyte of important stuff on it rest are games
sry for any typos writing in phone
ok i fixed this my self
here is how i did it:
1) i got my win 10 usb (the 1 i used to install windows on the pc in the first place
2) i then started the install u know language and stuff
3) and the repair this computer down i the left corner
4) then i got to the repair pc stuff and pressed shift + f10 to get cmd (just finding cmd under advanced ain't gonna work
5) i guess)
6) and then typed regedit
7) got into regedit clicked on the HKEY_LOCAL_MACHINE and then pressing files load hive
8) then navigating to X:\Windows\System32\config (idk what drive u installed windows on but its c: by default i think
9) fining the file named SAM and duble clicked it
10) then typing in REM_SAM as key
11) then i navigated to...
5) i guess)
11) then i navigated to HKEY_LOCAL_MACHINE\REM_SAM\SAM\Domains\Account\Users\000001F4
12) and modified then binary value in column 1 in line 0038 from 11 to 10
13) saving it and closing regedit
14)pressing continue to windows 10 and bamm it auto logged in as admin
14) the i brought up run (windows + r) and typed cmd
15) first i started to reset my old password by typing net user (insert username here) * (replace (insert username here) with ur user name and (remove the brackets))
17) then i typed my new password
18) then i typed msconfig looked under boot and unchecked safe mode
19) done restarted checked if i worked and it did
but it still logged in with the admin account so i got out an repeated step 1-13 but ) the binary value to 11 again
