Question Dead graphics card, acts in a wierd way. Please help
mirojasiu
72
I just bought a new graphics card that I got from eBay on an auction.
It is an Rx 470 8gb model from sapphire.
When I tried to boot up my pc, the graphics card was on, the lighting worked, but the fans did not spin and it did not post.
Any help will be appreciated 😊🙏
Fans will usually only spin when temperature goes high enough. The higher the temp goes, the more audible your fans will become. Are you talking about idle fan not spinning or is it not spinning when you are running, say a game.
Anyone???????
You should try replace the GPU FUSE (if you dont have one, you can short it). The GPU FUSE may look like this...
Source : Tomshardware Forum
