Question Dead Motherboard Check Guide
Feb 27, 2021
4
Hi, is there a guide somewhere online as to what to check when trying to fix a dead motherboard?
Something with component descriptions + tools you might need etc.
Thanks in advance.
Lutfij
Use a magnifying glass to look at each square inch of the motherboard from front to back to identify a blown or fried capacitor/VRM or SMD. Use a multimeter to probe each power delivery, input and output on the motherboard to see if there are any gaps in power inlet and outlets.
Tools;
Magnifying glass
Copious amount of light/lamp
Multimeter
soldering station if you want to solder components or remove damaged ones
Components(i.e, capacitors) to be replaced with.
You sure you can't take the laptop to a certified technician?
