[SOLVED] Dead PC? No power at all.
Jan 13, 2019
Hi there,
I just want some help or advice on what to do as my current PC seems dead. What I mean, is that I see no see no light motherboard when power supply is turned on and when I press the power on button there is no response by the system. I tried to unplug everything and give it a clean was evident however still no response. This made me to believe that it was the power supply and that was causing the problem. I did the 'paper clip test' and it showed no signs of the PSU fans moving.
This could indicate that my PSU is the problem but I want to be sure before I spend money. Furthermore I don't believe that it would be my PSU as it is a RM650x which is a reliable PSU. However I did buy it second hand of someone so it could be the issue.
I am wondering if it is the motherboard but unsure on how to check if it's faulty are not without a PSU. I have had this PC for 2 years now so it could be just getting old.
If you guys have any suggestions on what could the issue be that would be great.
