dead rising 3 Not running fullscreen
spawn1980
23
This is the problem I keep having
Go to the folder
Documents\My Games\Dead Rising 3
By default documents are stored in C:\Users\(Your name)\
Open the file rendersettings.ini with wordpad (wordpad lines it up and displays it better than notepad).
Change the setting WindowLeft and WindowTop to 1. If you set it at 0 the game will override it and reset it back to that ridiculous offset.
Then you can also change your ScreenWidth and ScreenHeight to whatever you want your resolution to be.
For instance here is what lines look like afterwards. My monitor goes to 2048x1152, so I have it playing at my full resolution. Most people will be 1920x1080
ScreenWidth = 2048
ScreenHeight = 1152
WindowLeft = 1
WindowTop = 1
My left and top kept setting to something like 370x190 so it was way off center. Setting it to 1x1 will make it only slightly off center.
