Hello,
I've been using my PS4 Slim with a Wireless connection for over a year without any problems, averaging a 20 Mbps download speed (measured both with the PS4 and a separate Ookla speed test).
Recently, after having upgraded part of my home network infrastructure, I've decided to switch to a Wired connection in order to get better speeds, right? Wrong! It alternates between failing to connect completely or having a download speed of 2-200 kbps.
My normal network configuration is as shown in Fig. 1 (Please note that the 10m long Cat.5 cable runs through the walls, so it is unavailable for upgrading). This is the router and these are the network switches (without management).
I have made several attempts to fix the issue, including:
Nothing I've tried has fixed this issue so far. Is there anything I'm missing / any solution to this?
Thank you for your time and help!
Fig. 1 - Normal network configuration.
- Configuring the PS4 Wired connection Automatically and Manually.
- Changing DNS servers (including Google's).
- Rebooting / Resetting the router.
- Shutting off or disconnecting every other device on the network.
- Bypassing one or both of the network switches (and chaining the cables together using couplers - see Figs. 2-3 for clarification).
- PC 1: 70-90 Mbps.
- PC 2: 250-350 Mbps.
- PS4 (Wired): 2-200 kbps.
- PS4 (Wireless): 15-25 Mbps.
- Laptop connected @ PS4 node: 80-90 Mbps.
- PS4 (Wired), bypassing Switch 2 (see Fig. 2): FAIL to connect to internet.
- Laptop connected @ PS4 node, bypassing Switch 2 (see Fig. 2): 75-90 Mbps.
- PS4 (Wired), bypassing both switches (see Fig. 3): FAIL to connect to internet.
- Laptop connected @ PS4 node, bypassing both switches (see Fig. 3): 80-90 Mbps.
Fig. 2 - Bypassing Switch 2.
Fig. 3 - Direct connection - bypassing both network switches.
