Deals Jan 18: 23" Dell IPS LED-backlit Monitor $169.99
There are small smartphones with 1080p res, Apple laptops with 2560×1600 or 2880×1800, and no significant amount of budget 27" monitors with greater than 1080p.
So for Dell...
Monitors = good buy
PCs = no?
I've lived for some years by the rule that anything with Dell's name on it is garbage.
Dell's monitors are fantastic. The high end ones at least (ie: $300+ for a 24"). Been using one of their 24" models that I got almost 10 years ago for around $800 (and that was on sale!) and I love it. Best investment I've ever made. Whenever I decide to upgrade, I'll be getting one of their $1000+ 30" models. Might be a while though.
Chowmein, IPS stands for in-plane switching. You might want to check out the tech specs again.
[citation][nom]Bhoward80[/nom]Chowmein, IPS stands for in-plane switching. You might want to check out the tech specs again.[/citation]
Ah, thanks I overlooked that. I just saw this one didn't say IPS and then DELL lists another 23" IPS display for $250 but you're right.
[citation][nom]A Bad Day[/nom]There are small smartphones with 1080p res, Apple laptops with 2560×1600 or 2880×1800, and no significant amount of budget 27" monitors with greater than 1080p.[/citation]
Well i got the 27" ACHIEVA Shimian QH270-Lite 2560x1440 IPS monitor for $320 on ebay. I am using it now, and my god! The blacks, whites! The colors! I can see everything with more real-state!
"DISPLAY
Diagonally Viewable Size:
58.42 cm (23")
Horizontal: 509.18 mm (20.05")
Vertical: 286.41 mm (11.28")
Maximum resolution:
1920 x 1080 at 60 Hz
Aspect Ratio:
16:9
Pixel Pitch:
0.265 mm
Brightness:
250 cd/m2 (typical)
Color Support:
Color Gamut (typical): 82%5
Color Depth: 16.7 million colors
Contrast Ratio:
1,000:1 (typical)
8 million:1 (Dynamic Contrast Ratio)
Max Viewing Angle: (typical)
(178° vertical / 178° horizontal)
Response Time: (typical)
7 ms with overdrive (gray to gray)
Panel Type:
In-plane switching
Panel Backlight:
LED"
No thanks....
FYI guys: That Dell monitor has a glass screen. So for those of you finally waiting for a glossy IPS screen to really have some popping colors, your wait is over. For those who complain that it is glossy, you guys have like literally hundreds of options that have a matte+ips screen combo, so don't complain ;P
