Question Deathmatch 3 RGB
Aeacus
Polypheme
Ambassador
Well, generic PC case with two 120mm ARGB fans and one 80mm rear fan.
Official specs: https://spiritofgamer.com/gb/cases/221-deathmatch-3-3700104427747.html
Do note that it only supports micro-ATX and mini-ITX MoBos. If you plan to go with ATX MoBo, pick another PC case.
Also, it's thermals look bad, since it has solid front panel with small vents for airflow. So, i wouldn't put much trust in it to cool the hardware.
If you want solid options (features, good thermals etc), then watch this:
View: https://www.youtube.com/watch?v=pL5uttjPWZE
GoldGlitch
Upstanding
BANNED
Nov 24, 2022
278
44
210
is it a good air flow.
btw tnx
Aeacus
Polypheme
Ambassador
Reactions: GoldGlitch
