i've been looking for a case for a while now since my old steel one literally started falling apart (for some reason one of the sides wont stay on anymore) and have narrowed it down to two.
either the lian li PC-60APLUS or the Antec P-180. my current opinion (uninformed really) is that the lian li is a lot lighter compared to the p-180, but the p-180 has much better cooling. (4 120mm fans and 1 80 mm fan!) it might be overkill but ive been told that not only is it cool its very quiet as well. ive also been told that aluminum "dissipates" heat better but since the p180 has 5 fans and the LL has 4 fans (2 x 120mm and 2 x 80mm) i think cooling wont be a problem in either case. im probably ordering from newegg and the prices are very similar so i dont think that will matter very much ($135 vs $125).
However, i currently have two beige drives (dvdr and cdrw) that might look pretty nasty on the lian li. supposedly there are stealth bezels for the case but i havent been able to find them on newegg so i dont know how well they work or how much they are. any info on where to get these, how well they work, and how much they are would be nice. the p180 on the other hand has a door so i can just keep it closed if the appearances bother me. im going to be keeping this comp in my apartment at school so i will only have to move it from school -> back home and vice versa twice a year. some issues that are bothering me are the length of my power supplies cables and whether i need to get convertors/fan controllers for the fans in either case. my powersupply right now is a thermaltake x silent purepower 480W. oh, and im trying to fit in about 3-4 hard drives (if that matters)
well thats about it, so any advice/opinions/personal experiences would be very nice on either case or any alternative cases and on fan controllers/powersupply necessities. sorry this post is so long -_-.
