Just moved to a new mATX case of a bitfenix prodigy M. I have the rampage iv gene 2011 socket and planning to SLI gtx titan blacks. I don't know if you guys know the layout of the prodigy m but I have two 120mm bitfenix spectre pros intaking air from the top of the case. If I want to SLI with one slot space in between the cards, these normal sized 120mm fans won't fit. Anyone have any good recs of any 120mm slim fans?
Unless you guys think it's better if I mount these fans outside..of the top of the case? If I were to do that, what can I put as a cover for for the case which I can fit under the fans?
