Decent card, low fps. Im a noob. Help! :) (750Ti)
MrEdzis122
Commendable
Mar 20, 2016
39
So i have the same card as my 2 friends, and they run eweryting allot better.
*LIKE* GTA V: on low i get only 30-40fps
H1Z1: on low 50-60fps
Rust is unplayable
My friends run all games HIGH/MED sett. on decent 60+ fps
Is it my CPU? PLEASE HELP! 🙁
My Rig
- Card: GeForce MSI GTX750TI 2GB GDDR5
- CPU: AMD X4 860K SFM2+ BOX/95W 4000mhz Turbo Quad Core
- RAM Kingston: 8GB DDR3 1600MHz
- Electric block: Fortron FSP350-60APN 85+ 120MM, SATA*3(2+1)
- Mother board: MSI AMD A68H SFM2+ MATX/A68HM-P33 V2
Windows 10, 1T memory HDD
Yeah the CPU is the problem. Thats the most that i get from this. The x4 chip isnt the best for single core performance. If you can sell that and pick up a decent i3 and overclock, you should be fine
just because you have the same gpu, doesnt mean you have the same computer
what specs are your friends rocking? run games on the same resolution?
yeah those games care a lot about cpu, yours is entry level
Agree with maxalge, but hardware doesn't mean much if there is more pieces to the puzzle your not looking at.
This is my monthly "to do" list when I service computers and what I recommend. 95% of all issues usually are 'underlying' things that suddenly 'kick in' when applying these methods. I would also recommend checking for any BIOS updates to the Mobo (check at Gigabyte's Website), just to make sure nothing is 'hiccuping' in the background that may cause 'some' of the over all issue (every little bit helps right???).
Did you install all Windows Updates? Including OPTIONAL except BING? Check them and repeat till ALL are installed.
Download and run Slim Drivers, install all the latest updates but you don't need to reboot until you do the last update
Go to www.filehippo.com, download Malwarebytes, go to CUSTOM Scan and set it to do a full system scan (by DEFAULT IT DOESN"T DO THAT, and AntiVirus doesn't pick up alot of malware) - this resolved almost ALL other similiar posts to date as most had Malware the AV didn't pick up.
Remove whatever AV your using and download AVIRA, AVG, Comodo or Panda go to CUSTOM Scan and set it to do a full system scan (by DEFAULT IT DOESN"T DO THAT) - this repeatedly has resolved alot of people issue relying on MS Essentials.
Repeat the AV/Malware scans till the system comes up clean.
Download and run SPECCY, copy and paste the first tab to show your idle temps
Download AUTORUNS and turn off anything NOT critical on startup, so you don't need to run JAVAScheduler to check for Java updates everytime you start your computer for example. BE CAREFUL AND KNOW WHAT YOUR TURNING OFF BEFORE YOU DO IT.
Open Computer, Can Air dust out the bunnies and use paint brush on the vents, coolers, fans, etc.
Go through and provide a response on each point, don't SKIP IT because "I ALREADY DID IT" , just try doing it again as of THIS post so we know NOW what is happening as compared to BEFORE you posted.
The only thing I can think of is that you haven't installed drivers yet. There is nothing wrong with your system and it should be capable of running gta v at least medium 60+ fps
I know right. I saw benchmarks on my card and CPU and guy played 1080P 50-60 at med sett.
i go only 720P and low sett and it lags the pc is new as well. like idk... still need an answer ;(
TY 4 Tips! 😉 but i dont think thats the deal, cuz its only 2 weaks old pc. and all the parts are new. Doe Ill try youre tips, mybe helps...
My friends run them 1080P or 900P and i just need 720P cuz my max is 900P and i know the card is good... And one of my firend has i7 thats a big diffrence, but still whit my cpu i should run at 720P smooth 60fps on med setts most of games...
I think so aswell... so yea what u can suggest the best CPU? for the buget?
not really no
20 - 40 fps is about right for gta5
you are running it stock correct?
What means stock? im a noob 😀
stock means the speed it runs at without modification
i.e. non overclocked
