Approximate Purchase Date: As soon as my building gameplan is all set up.
Budget Range: Under $400
System Usage from Most to Least Important: Gaming, everyday web-browsing and media
Parts Not Required: Keyboard, mouse, monitor, speakers, OS, PSU, HDD, GPU, DVD drive
Preferred Websites for Parts: Newegg.com, Amazon.com
Country of Origin: United States
Parts Preferences: AMD CPU
Overclocking: No
Crossfire: Maybe in the future
Monitor Resolution: 1920x1080
Additional Comments:
Right, so first off let me explain that this isn't an entirely new build, more like halfway. Since that includes the motherboard and CPU, I'm hoping I'm not posting in the wrong place.
So, I have a fairly decent rig atm, but the main issue is the motherboard, an M2N68-LA (Ivy8). According to HP site, I can't really upgrade my processor much past my current Athlon 64 x2 4400+. If I'm wrong, please tell me, because that would save a good bit of money. Anyway, I'd like to keep power low (noise too), while still having some good specs.
The parts that I already have that I want to use are as follows:
DVD Burner/player
XFX ATI HD Radeon 6670 1GB GDDR5 RAM
Seagate 250GB 7200RPM HDD
Western Digital 320 GB SATA 6 Gb/s 7200 RPM 16 MB Cache WD3200AAKX
Antec EarthWatts Green EA-380D 380W PSU
Windows 7 Ultimate x86
So, naturally, any build I have will need to be compatible with the above. I'm not a master of pc parts (obviously), but I'd guess the PSU is the only real potential limitation. The parts I've looked at and think would work well with my build are as follows:
For the case, Cooler Master Elite Mid Tower Case, RC-310-BWN1-GP -OR-
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
For the motherboard, BIOSTAR A870 AM3 AMD 870 SATA 6Gb/s ATX AMD Motherboard -OR-
GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
For the RAM, depending on the motherboard chosen, G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) -OR-
Kingston HyperX T1 Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1866
And last but kind of most, for the CPU, AMD Athlon II X4 645 Propus 3.1GHz -OR-
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz -OR-
AMD Phenom II X4 945 Deneb 3.0GHz -OR-
AMD Athlon II X3 455 Rana 3.3GHz
Far as the case goes, I'm leaning more towards the challenger because it has space to put away wires, the 3.0 usb connectors, plenty of ventilation, *seems* to include more fans... and it looks kinda cool. Only thing is, will the bottom mounted PSU pose a problem for the PSU I've got (coming in the mail actually)? Either in terms of air flow or connectors reaching?
The motherboard I'm pretty stumped on. $45 difference is pretty big. Is AM3+ something I'd notice over the AM3? The Biostar only has 4 USB, but with the case I'd have 6 anyway. I don't know anything about connectors or space, so do either have a problem with the cases or otherwise in that respect? The Gigabyte has more plugs and supports better (I'm assuming) RAM, but how important is that? Will all the extra features use too much power?
I really know nothing about RAM. I assume the higher numbers of the DDR3 RAM indicates better performance, but I have no idea how much if so. Keep in mind I'm running 32-bit and can't use more than 4GB. RAM doesn't use much power does it?
Coming to the CPU... The one I have now is I think 65TDP, so 95TDP would seem a moderate power level, thus the Athlon II 645 seems a good option. The Phenom II 965 would be even better (Phenom II > Athlon II?) but the 125TDP may just be too much. Phenom II 945 would work, but it's currently sold out on Newegg. The Athlon II 455 is just the more budget friendly option, but I'd prefer 4 cores to 3.
All in all it's looking to be around the $300 price range. If you've spotted different items than I've listed you think I've overlooked, please feel free to show them to me. I'm mainly interested to know about any possible conflicts that could arise from any combination of the above, such as power limitations, incompatibilities, or physical space issues. Also, have I overlooked anything I'll need? I know I'll need thermal grease for the CPU, but beyond that I'm clueless. Secondly I'd like help figuring out the best performance for the money option for what I'm looking for in a PC. If you need further details, just ask.
I appreciate any and all help provided, and I hope this isn't too difficult.
Overclocking: No
DVD Burner/player
