Decent power supply
bolejniczak
7
Hi all. i am looking to get a 650W power supply. This one is one sale, 36% off. EVGA SuperNOVA 650 G1 120-G1-0650-XR 80+ GOLD 650W Fully Modular. My question is, is this a good quality power supply?.
Thanks
Brian Olejniczak
No. Group regulated load regulation, not good transient response, loud, and usually overpriced. EVGA SuperNOVA NEX750G 750 W Review
Right now it’s priced at $76 USD, even with 36% off at $50 it isn’t particularly good value, seeing power supplies like the Corsair CXM/CX and be Quiet Pure Power 10 at that price.
Your system likely only needs a 550w power supply unless it’s a threadripper/i9 with top end GPU. Look for a Bitfenix Whisper, Corsair RMx, Seasonic Focus Plus, or the EVGA G2 - if you don’t mind noise.
What are your full system specifications? Where are you buying from?
I would say not bad and would work if you're very budget limited. However if you wanted better quality for a little bit more, have a look at EVGA's G2 series or G3
The series are made by different manufacturers, and the latter series are much higher quality. 😉
