Dedicated sound card for hyperx cloud1
Yellow3
Commendable
Dec 1, 2016
5
do i need a dedicated soundcard for thehyperx cloud 1?
I want a good headset for gaming( around 100$)
motherboard:ASRock B85M Pro3
Sure. You'll See an improvmemt. But a good sound card is around 70-120$ and the improvements won't really justify that while a cheap low end soundcard won't make a difference
Best thing is to just test it. If you don't like the sound quality get a sound card.
do you think it's worth to buy the headsets with my current motherboard?
(for gaming)
(for gaming)
Usually the Mainboard Codec is still sufficient as the headphones are the more limiting factor anyway.
Those are solid headphones go for it.
If we were talking about 250$ Sennheisers or AKGs things look different but in your case they are quite alright.
but the downside is that i can't use the adaptor?
