deepcol Gammaxx 400 vs cooler master Hyper 212X performance difference?
NonTechSavvySheep
224
can you show me the benchmark? will Hyper 212x fit in micro atx case? I heard that Hyper 212x is like hyper 212 evo but with extra fan. id it possible to install one fan only for hyper 212x? the shop only sell hyper 212x, they didn't sell hyper 212 evo anymore
They offer aboput the same performance.
As ofrt it fitting the case, that obviously depends on teh case itself.
EDIT: must be said that the Cryorig H7 is a better cooler than both and very much worth every extra penny. Also, it's lower profile(145mm height) so it'll fit many more cases.
Hello.
The GAMMAX 400 can be noisy sometimes. I've long since replaced mine with a PWM Cougar fan. As for performance, with the stock fan, the Hyper 212X should be better. The Gammax 400 wasn't better than the 212EVO after all.
Check that here:
http://www.frostytech.com/articleview.cfm?articleid=2696&page=5
When looking for a casing, check the rated "Maximum CPU Cooler Height". The GAMMAX 400 is 154.4MM high, and the 212X is 158MM high.
CRYORIG H7 - Entry Level Cooler Price: Rp 450,000
Cooler Master HYPER 212X TURBO Price: Rp 540,000
Deepcool Gammaxx 400 - Fan 12CM LED Price: Rp 308,000
if Hyper 212X turbo is FAR better than Gammaxx 400 in every aspect. then, I will justify the extra cost. if It only wins slightly then I will stick with Gammaxx 400
The 212 si not worth teh extra cost, but the H7 definitely is. My recommendation stands.
noctua is too expensive too me. I can afford Cryorig H7 and deepcoold gammaxx 400. since h7 cools much better, I just use H7 then
