Question Deepcool 360EX RGB is not mounting in Nzxt h710 case
Oct 25, 2020
Hi All,
I am building a system with deepcool 360EX RGB cooler with Nzxt H710 case. I have noticed that this cooler is not fit in top side of case. shall i mount this coolder in front side of this case and remove the in-build front side fans and mount it in top?
Oct 25, 2020
Thanks for your reply. Does it create any hot air flow inside the case and affect cpu?
I am going to connect the cooler in front panel as below,
inside case -> coolder fan -> radiator -> front panel
Top side of panel -> connect 3 front in-build fans.
Karadjgne
Ambassador
When you mount fans interior input, that's called pull. You pull air through the radiator. Works best when fan rpm is lower, like under 1k rpm or so.
You'll need to mount them where the ugly side with the visible motor housing and wires is facing towards the inside of the case.
The top fans, you get to see the pretty side from the inside.
