DeepCool Announces 1250W Power Supply
InvalidError
If your wife can sleep through you using the PC, I doubt the fan is going to wake her up... unless the designers did something silly like set it to max voltage on shutdown.
My guess is they are simply feeding the fan controller off an extra 12V output on the 5VSB transformer to operate the fan and its thermal control independently from the main rails. If the PSU was not warm enough to run its fan while the PC was on, it won't run after it gets turned off. If it was running, it should not get any louder than it was prior to shutdown either.
