[SOLVED] Deepcool CPU coolers and Fans
rohaansaifi895
45
Hi
I have completed my build and now I m focusing on to CPU Cooler and ARGB Fans for my build.
I have checked Cooler Master Coolers and fans, Thermaltake Fans and Deepcool Fans and Coolers.
From searching I came to know that Deepcool is good and budget option also I want to use ARGB whole build not RGB.
Deepcool`s CPU cooler and CF120 ARGB fans are my choice mainly.
So all I wanted to ask that which CPU cooler will do best in my build with slightly overclocking and CF120 are good fans or something other I should know?
Suggestions are welcomed. Some friends advised me to use ID Cooling CPU cooler some saying Hyper 212 Turbo (as it has no ARGB so I am confused).
So guide me about this!
Thank You!
Make sue he fans work with whichever ARGB controller you plan on getting.
[edit] Also consider if you are going to be able to see the cooler's fans once it's all installed into the case you've picked out. Often you can't since they face forward.
Reactions: rohaansaifi895
