deepcool dukase front panel
MADGOD_3
Commendable
Sep 29, 2016
15
need help opening the front panel of this case for intsalling the fans....its like a whole day now trying to figure it out..no luck..anyone..helP>>!!!!! my baby outa fresh air..!
Front panel door is magnetic and it opens to the right side if you pull it.
Once you have opened it, reach below the front I/O panel and you should feel small gap between case and front I/O panel. Put your fingers in and pull. May take some muscle to do it but most mid tower ATX case front I/O panels are removed that way. Removal of the front I/O panel is very similar to a top I/O panel removal.
Woah!! Thanks hey it worked...!!!!!!!!!! for this case the gap is at the bottom.. And yup required some brute force to pull if off..!
