[SOLVED] Deepcool Gammax l240 fans spinning but no rgb working
Mar 26, 2020
5
hi, i have an aio whihc is the DeepCool gammax L240 and the fans are spinning when i turn on the pc but the rgb isnt working. I am completely lost in what i should do and my motherboard is the MSI B365M pro-vh. Help please
Your motherboard doesn't have a 12v RGB header. It doesn't work in just any 4-pin header.
You need to get an add on card like this: https://www.amazon.com/Taurus-Control-Mystic-ASROCK-BIOSTAR/dp/B0743LGBNH
That, or replace the motherboard, but that would cost a lot more...
oh wait hold on, my case is the Thermaltake versa j25 and at the back it has this connector that fits with the rgb adapter from the deepcool box, i plugged it together but still the rgb fans on the aio will stop not light up.
