Deepcool Gammaxx 400 cooler good for Ryzen 7 1700 oc'd @ 3.7ghz?
Oct 5, 2018
Is the Deepcool Gammaxx 400 cooler sufficient enough to keep the Ryzen 7 1700 oc'd @ 3.7ghz at good temps?
Case: Phanteks P400 ATX Mid Tower Case. (2 fans total, 1 rear, one front)
Also, if the Deepcool Gammax 400 isn't any good, whats a good cooler for the Ryzen 7 1700, preferably one that is around the price range of 16$-30$.
Any feedback would be much appreciated, thanks.
Much appreciated man, thanks for your insight, and the cooler you recommended looks very promising, thanks again.
You are limited to a cooler that is 160mm tall with your case. These three maximize the cooling, but are still under $50.
$45
CRYORIG H7 Plus Dual Fan Tower Cooler For AMD/Intel CPU
https://www.newegg.com/Product/Product.aspx?Item=9SIA4UF7KA8600&ignorebbr=1
$44
DEEPCOOL FROSTWIN-CPU Cooler 4 Heatpipes Twin-tower Heatsink Dual 120mm Fans One with PWM Metal Mounting Kit
https://www.newegg.com/Product/Product.aspx?Item=N82E16835856004&ignorebbr=1
$49.99
Cooler Master MA620P Twin Tower RGB CPU Air Cooler, 6 CDC Heatpipes, Dual 120mm RGB MasterFan
https://www.newegg.com/Product/Product.aspx?Item=N82E16835103265&ignorebbr=1
