DeepCool Gammaxx 400: Question about the LED
Zedes1
Commendable
May 24, 2016
After reading this site's review of this cooler, it seems like a great deal. However I do not want the blue LEDs. Do they turn on automatically when the fan does, and if so is there an easy way to disable/remove them? Ideally I'd like red LED, but no LED at all is quite fine. Thank you in advance for your help.
Hi, yes the LEDS are built into the fan and cant be disabled. You would have to either just buy a different fan and use that or remove the LEDS from the fan. This can be done with a pair of pliers and scissors.
Thank you :)
