Question DeepCool LS520 AIO Cooler VS Peerless Assassin 120
poodude28
121
Hello, I currently have the Peerless Assassin 120 air cooler and want better temperatures, is the DeepCool LS520 AIO going to result in that or is it not going to help?
I am getting up to 82 C on some of my p-cores on cinebench r23 but in games it seems to be fine, should I be worried?
I run at 5GHz on my i5 13600k
Make and model of your case? Number of fans in your case and the orientation of said fans in your case? Make and model of your motherboard?
Could I just get an answer about whether or not that aio cooler is better or maybe a suggestion of which aio cooler I should get? I'm also trying to think of the future because I was going to upgrade my GPU eventually and I can only assume this will impact my CPU temperatures.
I get around 65 degrees in OCCT Large and Medium Dataset, so maybe I should take Cinebench with a grain of salt.
Can't be done without enough information, or be stuck in speculation hell... or someone who has at least played with both coolers chimes in, but that could take some time.
No need to be worried. You still have headroom on the table.
Tbh it gets as high as 87 on there, but OCCT Medium and Large always stay around 65.
