A FAT DONKEY 55 :
weberdarren97 :
You will be forced to run them in single channel if you use this cooler. 🙁
I am having a computer shop install the parts so they will probably mount it so the RAM fits.
Have you made sure that they know what they're doing? I've been screwed over by many "computer shops" and most "computer doctors" just load more "preventative programs" onto your machine and bog down the CPU and disk.
I don't have a problem with either of those components, I just want to make sure you don't have any problems.
Wait a sec, do low profile DIMMs come with heatsinks or not? Having RAM heat problems could ruin the experience of using a high end motherboard and CPU
