So i bought the mentioned case, here's a link if you want to see it: http://www.newegg.com/Product/Product.aspx?Item=N82E16811853004
When i finally had all the parts to put it together, I kind of impulse bought a fan. Corsair SP120 fan that lights up red. The red glow through the case is great. Problem is, it's a static pressure fan, probably not the best for a case like this that has all the room for air flow. The case came with one exhaust fan installed in the back. Question is, do you guys think it's fine to have a pressure fan intake air and another fan (probably air flow optimized but also probably not very high air flow) as the exhaust, or should i just move the fan from the back to an intake in a different area of the case, like the side panel (or the top which has removable mesh air filter) so that i can have passive exhaust with positive overall pressure.
System specs are:
MSI Z170A Pro Motherboard
Intel i3 6100 Processor with Stock Heatsink
2x4GB G.Skill Ripjaws V 2400mhz ram
2x1TB Samsumg 7200rpm HDDs
1x240GB Kingston HyperX SSD
1 Very noisy Optical drive
System under medium load (igpu 99%/cpu 50-60%) usually around 60-65 C.
System specs are:
