Question Default fan speed is little bit low
Sep 3, 2019
24
Hi,
I have an msi 2080ti trio.
The default fan configuration is a little bit low or so I think. I'm not sure what is the exact config but when I use them the gpu temp reach up to 78c.
I decided to use a custom config which is:
%0 until 50c
%40 until 65c
%60 until 77c
%100 for above
After this configuration the temp is around 70c at max load with ~%60 fans speed.
I feel like this makes more sense than the default one.
My question is the custom configuration above better or should I just return to the default ?
Edit: I don't care about the noise. I don't even hear the fans because my ac is a little bit loud.
