[SOLVED] Defeated! Aorus x570 Elite no POST with Zen 3 5600x
dspec
17
I was lucky enough the other day to grab a 5600x at local MC store but wasn't sure what MB to get. I went back today and picked up the Gigabyte Aorus x570 elite.
I get home hook everything up and boot and it doesn't POST. Fans/CPU etc are all working but just a black screen. No Keyboard or mouse or USB work. Started to look online and found the Q flash + feature.
Follow all the directions and when I click the button my USB drives flashes for 10seconds and nothing. Apparently there is a LED light above the button on my MB and that doesn't light up either. So I removed everything but my power and MB, no cpu etc and same results.
Any advice? I'm so defeated as this is the first build I've ever had issues with. Which this year along this is build #4. but ive never had bios and new gen to deal with.
dspec
17
Hi dspec.
That motherboard doesn't have the BIOS update needed to support the Ryzen 5600X BUT you are lucky that board can be BIOS updated without a CPU installed.
View: https://www.youtube.com/watch?v=y9uGfIFufZI
https://www.youtube.com/results?search_query=x570+aorus+elite+qflash
thank you, I'll try what he does in a bit. I found like 3 other "guides" with zero luck. when I hit the q flash button my USB stick lights up for maybe 10 seconds and stops. I see the q flash button has an LED right above it but it never actually lights up.
dspec
17
Do the rest of what the guy does in the video after the download of the file and renaming of the file. Start at 1:40.
I’ll confirm what version I have and yes I did do what you suggested but going to start over fresh. It’s been a few hours and I had time to cool down so to speak
dspec
17
