I am having an issue with my PC being ungrounded (I believe) which is causing my front USB ports to act weird. These front ports will randomly disconnect/reconnect when something is plugged into them and one of them doesn't work at all. I have gotten 2 new Front IO panels and they have all had the same problem. I have reinstalled windows, reinstalled the USB drivers, reseated my motherboard, unplugged everything from inside the case and nothing seems to work.
My PC is plugged into a power strip that has the lights to tell you if it is grounded or not and they are not lit up. The only time I can get the grounding light to come on is when I plug a device into one of the front USB ports and set it on my desk (As weird as that sounds)
Any help would be greatly appreciated.
