Hello fellows,
That might be little stupid question, but i'm actually struggling over that about a month. I have a Panasonic TV on my room, which is simple 1080p 60hz hanged on wall, for watching netflix and movies. My primary monitor is the Dell 27" S2716DG with 2k resolution. I am using them both as duplicated desktop, mainly because I hate the fact my mouse sometimes run away to second screen etc. The problem is, almost every game in my computer identify the panasonic tv as primary monitor, even i'm setting the dell to be it. I have tried to set them to extended, and define primary, still not helps. Tried to turn off the tv while I'm playing, still don't work.
Currently, my only solution is to crawl down under my table and plug out the panasonic in order my games identify my dell, and allow me run on 2k resolutions. The tv plugged in with the HDMI, while the dell plugged with dp3. Its became quite annoying thing because I'm doing it routinely every day and I'm sick of breaking my back every time. Is there any solution for this issue around?
Thank you!
Thank you!
