So after spending a couple hours gawking over different PSUs, and trying to figure out what was actually relevant in a quality PSU, I decided to admit defeat. I do realize a good PSU will serve you better than most other components over time, so getting it right in the first place is key for me. (and I'm sure anyone else for that matter)
I hail from the US, and from what I can tell, $80-$100 seems to be the sweet spot at getting some decent 80 plus certified units in the wattage range I'm looking for. I get a little concerned with anything sub $60 since I don't know what to steer away from. My setup will consist of the following energy suckers. Mainly a i7 2600k, a Radeon 6870 (with a probable 2nd in the very near future) couple HDs (one being a SSD), and an optical drive. I'll be looking in the 650 watt range with 750w most likely overkill for my needs.
With all the information I've been soaking in over the past couple weeks about everything computer, my poor brain is stuffed and a bit fried. I looked through some example combo deals for units at Newegg in hopes of finding a little something to match my needs, and usually a case is a good combo bet. (but that's a whole other topic for another thread)
I'd link some PSU examples from Newegg, but I already feel dumb enough as it is. What am I looking for guys? Could you toss me a couple examples of what I need to be looking at, and why I'd want that PSUs particular feature or advantage over something else?
