Deleting "System Reserved" Partition
EagleDesignInc
231
Recently I switched my primary Windows 7 from a HDD to SSD.
I copied the windows files from the HDD to my new SSD using the Macrium Reflet
After the migration I format the old HDD and now I'm using as storage.
The problem now is that I have an assigned drive letter (F) to the System Reserved.
How do I delete that partition???
1. Verify the system will boot without it.
2. Check your pagefile settings. Remove that from the list.
I cannot delete using Disk Management. It says: This partition has an active paging file
But it also has a hidden System Reserved attached to the SSD...
I removed the pagefile from the partition F and I successfully deleted. Thank you.
