[SOLVED] Dell 790-Power supply
Nov 9, 2019
4
Hello! I want to buy and upgrade a Dell 790, i want to upgrade to these specs but im concerned about tyhe 240W power supply in these models. will it be a issue? ive been reading mixed opions on it, some say its been working in there machines for years and others keep saying its not a good idea. so i dont know who to belive...
Specs i want to upgrade too:
I7 2600
GTX 1050TI OC (Low profile)
16GB of 1333MHZ Ram
240GB SSD
(Case is a SFF)
Is there going to be a issue with the PSU here or we ok?
Thanks!
4
Well you can't upgrade the PSU in the SFF , the board and power supply are proprietary. SFF setups aren't worth upgrading or buying to limited.
ive read many forums of people who have done a grape SFF with no issues, and ive heard the power supply can handle the i7 and gtx 1050 LP but i just want some renforcement, i appreciate that you suggest i dont do this, but i understand what im getting myself into.. i just wanna know if the Stock PSU can handle it, becuase ive heard some mixed opions on this. so just checking before i finalise everything..
