Hi Tom's Hardware:
I have a DELL AIO 964 printer that has the folllowing problem: When the printer is turned on, the green power light comes on, but the LCD panel comes on with a dull grayish color-and is blinking slightly. You can't see anything on the screen, therefore, you can't instruct the printer to do anything. Also, I noticed a red light comes on - inside the printer- at the lower right-hand side.
If you press the power button to shut off -- the LCD screen stays dimly lit -- but the red light does go off. The ONLY way the printer will shut off is if you pull the power plug out of the wall.
Finally, if I'm working on my DELL lap-top, I can command my printer to print out a screened document -- and it will do it with no problem! I can print out as many copies as I want to.
HELP !!! What is going on?????
Thanks.
Thanks.
