Dell Auto Adjust monitor issue
irCRiz
212
Ok, so i have a Dell SE198WFP and if i go into the menu of the monitor all the options show up but auto adjust and positioning are both unselected able. This is really annoying and i just want to figure out how to fix it.
there is also one more issue it say that the optimum setting should be 1440 x 900 at 60hz but everytime i lower my hertz from 75hz to 60hz my window always goes into the basic theme and it wont let me use the windows 7 aero theme.
Let me know if you need more info or know answer.
Anything you might be able to help me with will be greatly appreciated.
Thanks
75hz vs. 60hz on an LCD monitor doesn't make as big a difference as on a CRT, but as long as your monitor supports 75hz, I see no reason to force it down to 60hz.
Ok that helps alot already thanks.
Isnt running the monitor at 75hz better anyway
ok thanks
