Hi all,
sometime around Jan 15-20 this year a message started popping up on my Dell Precision M4800 stating that the 130w power supply I had plugged in was under the recommended 180w and in short it was going to throttle system performans/not charge etc. (I think I might have done a BIOS update around the time but can't remember if it was before or after the issue and a rollback to the previous version doesn't fix the issue). I have been running said 130w charger for the 2ish years i have had the system, (and it is a 130w charger not an error). The performance has been throttled (cpu running at constant 300MHz out of 2.7GHz+ cpu) which I have gotten around using throttlestop. However the charging circuit also seems to be somehow being affected, battery now taking 2-3 hours to charge 5% if in use- 1-1.5 for a full charge if not turned on.
If anyone could help me get around this without shelling out $100 and lugging around a bigger charger for what seems to be some form of Dell forced upgrade stunt it would be most appreciated.
I don't see how a laptop with
