Dell dimension 9200 power supply
dcote76
Here's what in the Dell Dimension 9200 :
375 Watt DC Power Supply
Heat dissipation: 1280 BTU/hr
Voltage: 90 to 135 V and 180 to 265 V at 50/60 Hz
Backup battery: 3-V CR2032 lithium coin cell
Is it good?
apt403
2,923
Any psu by dell is crapy, but i guess it all depends on what you want to do with it.
You cant tell much by those specs btw, try to be more specific.
dragonsprayer
Splendid
Jan 3, 2007
3,809
funny u wrote that "back up battery lithium" lol
dell uses the cheapest $10 psu u can find - check the amperage and find a similar one!
if u upgraded parts then add some amps
Similar threads
