• Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Dell Dimension E521 starting normally problem
nick2315382
5
I have a Dell Dimension E521 and i am not sure why but for some reason when ever i try to start it, on the boot up screen it has weird blue lines up and down the screen then after that I keep seeing $ signs up all over the screen next it say windown can not start normally i try to fix the errors but it says no errors detected plz help
Kisianik
Dignified
First, just in case, most likely not going to help - last know Good configuration
Second - Safe Mode. In Safe Mode all drivers stop working, only Windows essential ones, so if problem persists, it is most likely hardware.
How long you have this problem, does this start as soon as you start PC, or after a while, is your PC fans start working to fast when it is happens?
nick2315382
5
it give me an choose of either launching start up repair and starting it normally
nick2315382
5
finnally got it the opitions are
Repair Your Computer
Safe Mode
Safe Mode with networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable low-resolution video
Directory Services Restore Mode
Debugging Mode
Disable automatic restart on system failure
Disable Driver signature Enforcement
Start Windows Normally
(my hands hurt :-\)
which one
nick2315382
5
also i play these 2 game called "World of Tank" and "World of Warplanes" do you think that it could of have caused some type of virus. (Also when i downloaded it said the games can harm your computer A.K.A my computer)
Kisianik
Dignified
