Dell Inspiron 3847 cooling help, thinking about using side panel for a fan.
Jun 29, 2016
27
The Dell Inspiron's case has terrible airflow, only sporting the rear exhaust and CPU cooling fan as the only fans with the system stock, no dedicated intake fan.
This is what the case looks like with a GPU in it: https://cdn.pcpartpicker.com/static/forever/images/userbuild/141673.810d3647212e30633da71d61fd707a22.18009d3fb0fba7929b98d5269097430a.1600.jpg (My GPU is longer than that one, an ASUS Strix 960, around 8.5 inches long)
So I can't find a spot to mount a fan onto the metal behind the front panel, so I thought to get a 120mm fan and zip-tie it to the side panel's vent (right over the CPU cooler).
Would that be a good way to solve the intake issue? I know a new case is the best solution, but it's beyond my budget fight now, even budget cases. Plus I wanna save for a case, like a good mid-tower in the $70-105 range.
Swirlz
Commendable
Aug 10, 2016
145
9
Well zip tying it might cause some issues with the fan, but could you send a picture of the front part of the case. There might be a way to put a fan on.
DeezyE
Commendable
Aug 12, 2016
5
ziptieing it wont be a problem but you will have to get a pin splitter since there are only 2 connectors, for the exhaust and cpu fan
Jun 29, 2016
27
With Overwatch, I set it to Medium at 900p (I use a 21in 1080p moniter, so it doesn't look that different from 1080p) and my 960 gets 45-60c temp range with fans set around 70% (card uses 2 fans that max around 3300 RPM. The CPU stays up in the mid 50s range during playtime and is usually 32-42c when browsing/idle.
DeezyE
Commendable
Aug 12, 2016
5
80mm fan fits perfectly, haven't tried any bigger fans tho you might be able to fit a 92mm fan if you move some of the cables
Similar threads
